I’m using the latest version of OpenNest2 in Grasshopper/Rhino and I have a setup with two OpenNest2 nodes in series:
OpenNest A : nests pieces into offcuts (chutes) from a CSV file
OpenNest B : receives only the unplaced pieces from OpenNest A (detected via Sheet Id = -1) and nests them into standard panels
The problem : OpenNest A keeps its results perfectly after calculation (displays “10 gens → X sheet(s)”). But OpenNest B always erases its results after reaching gen 10 — the pieces disappear from the Rhino viewport immediately after the calculation ends.
Both nodes are the exact same version. The only difference is that OpenNest A has a Data Dam upstream stabilizing its inputs. I have tried adding Data Dams on all inputs of OpenNest B (Sheets and Geometry) but the results still disappear.
I have also tried pressing ESC during calculation but it displays “stopping… gen 0” and also erases results.
Is there a way to freeze/keep the results of OpenNest B after calculation, the same way OpenNest A does naturally ?
Thank you
