Since updating Rhino 8 to SR 25 Rhino.RhinoDoc.OpenHeadless sometimes fails and returns None instead of a RhinoDoc instance.
I’m using IronPython nodes in Grasshopper v1.00.8
On SR24 everything was working as expected but since SR25 I sporadically get the object expired during a solution error (see attached screengrab)
The code I’m using is:
assert os.path.exists(this_file_path)
this_file = Rhino.RhinoDoc.OpenHeadless(this_file_path)
assert this_file
If I replug the inputs and rerun a couple of times it works, but it is erratic.
I cannot share the models I’m using right now but wanted to check if anybody else is experiencing this.
Regards,
Iván
