Hi, I’ve been creating this roof design which intianlly worked fine (shown in the two images below), but I made some changes to the column postions on the floors above and need to update this ceiling design again with these new conditions. I’ve identified the problem, but I’m unsure exactly how to fix the issue.
I’m using a plugin called (flexibility) to achieve the offset curve as it was the only way I could create a bend effect in the final result. However, the script seems to remove some curves which is causing the loft compotent to fail, it lists 2190 curves when there should be 2193.
The bend effect across all of the louvres
Custom Flexility component which lists 2190 curves
Standard componets which lists 2193 curves
For the script to work for you make sure you have Flexbility and Pufferfish! Thanks!
GH Script: Lower_Levels_Roof_Design_Level_2_(Help).gh (311.4 KB)
