Hi
Would it be possible to offset a non planar polyline in Grasshopper with differen values?
For example:
Side A = 10mm Offset
Side B = 15mm Offset
Thank you!
Jonathan
Hi
For example:
Thank you!
Jonathan
Any reason not to create the offset curves separately, one on each side with the desired offset distance?
I am not sure if I then can join it again to a closed curve again (since it is not planar)
The directions of the offset will probably be chaotic, so I would need to offset each line-segment in both directions and then figure out which one to take
I then need to trim and split each line before joining them again
Can you provide a file with an example of the input and the desired output?
Hey David,
I guess I would need something like this:
Thanks for your help!
this should be reliable as long as the offset of the sides intersect each other
but when something like this happens it’s game over ![]()
there might easily be better solutions… ![]()
