Hello experts, I have problem getting the outside offset corner sharp, Is there any way please to fix it?
Thank you,
Nada
Thank you,
Nada
That is the dialog for Offset
. The title of the post suggests that Nada is using OffsetCrvOnSrf
which does not have an option for sharp corners. A post from six days ago about the same issue which includes a work-around to obtain a sharp corner:
Sharp corners should be an option with OffsetCrvOnSrf
Someone from McNeel will need to agree and put it on the heap of requests.
You are right, I misread the title, sorry for the confusion.
Thank you Phos4 for your reply, I do have these options in Offset command but not in OffsetCrvOnSrf!!
Could be bug?
Thank you David, so is there a way to fix it or not? Appreciate your help!
@Nada The thread I linked describes a method to obtain sharp corners. Did you look at it?
It does not appear possible to have OffsetCrvOnSrf
produce sharp corners directly.
Thank you David! Yes I read it but I was a bit confused, sorry my mistake but it is clear now
Hi Nada -
I have added your vote to the open feature request - RH-23754.
Thanks,
Thank you Wim!
