I cannot get past this odd problem with booleans and closed polysurfaces, and hope you could point me in a new direction.
I have two closed polysurfaces. I would like to subtract the one on the right of the image from the other.
I have checked for bad objects, invalid surfaces and non-manifold edges, to no avail.
I have checked the intersection of the two solids, and it seems good to go.
BooleanUnion yields expected result.
BooleanSplit and BooleanDifference yield the following: the polysurface I am trying to subtract from is marked as a closed polysurface, but there is definitely something wrong there.
Hi Alexia -the Boolean is correct as far as I can see- the naked edges are on an extra surface that is conicident with the bottom face of the smaller object.
I have hidden that surface and made sure to select the two polysurfaces in question when calling that command, but I am still getting an abnormal result: do you have any idea what else could be going on?
Yeah, I see the shading is incorrect - that means the surfaces are incorectly oriented - still poking…
You can ‘fix’ it by exploding the the thing and rejoining, but I don’t yet see what is causing this.
Ah - it is very far from the origin… @ak_epfl move the inputs to the World origin before the Boolean - that should look better.
This has to do with the way that Rhino 5 creates display meshes. Rhino 5 uses single-precision floating point numbers for these - Rhino 6 uses double-precision.
A lot has been written here on the topic. A few links:
