I’m getting this cage wireframe that readjusts itself larger or smaller when an object is moved. I’m using my custom rendered mode for viewing which has worked fine until this wip and did not show these cages on every object.
RM
I know this setting wasn’t checked because I’ve been using this mode for the duration of the wip and display bounding box wasn’t showing in the viewport but I just found it was checked, selecting use application settings resolved the wire cage showing.
Checking again, under dynamic display usage, “display objects bounding box” with “only during view changes” selected appears to be not working, Rhino is defaulting to always showing the bounding box.
RM
