Object description questions
Why does the object description for straight lines not show degree 1, 2 points?
What is index (-1)?
Object Description.pdf (353.5 KB)
Hi @tfostermorphis,
Not all curves in Rhino are NURBS.
– Dale
That’s the render material index. If there is no material applied, it is -1.
Thanks.
Thanks…
What is this non-nurb curve name and purpose?
Tommy M.
Hi Tommy - I am not sure I understand the question but there are different ways to represent curves - some are NURBS and some not - the typical soft and swoopy curve in Rhino is a NURBS curve, but joined curves are ‘cpolycurves’ of which some segments may be NURBS, Arcs can be NURBS or not , polylines are really just an ordered series of points made into a curve, etc. ToNurbs will nurbify any of these:
Thanks you sir,
If creating a rectangular surface from four straight edge curves,
would single span nurbs, same degree and point count on opposite sides be preferable?
Best,
Tom M.
Hi Tom - for the simplest cleanest surface, yes - though, if you are working with single spans, opposite curves need not have the same degree/point count - the surface will inherit whichever is the highest degree. Same in Loft, btw.
Once more, thanks…
