I am trying to write a Python script to iteratively calculate the normal vector at a specific point on a polysurface selected by the user.
I have written the code as follows, but it’s producing an error.
rs.SurfaceNormal used
def calculate_normal_at_points(polysurface_id):
while True:
# Prompt the user to select a point on the polysurface. Exit the loop if canceled.
point = rs.GetPointOnSurface(polysurface_id, "Select a point to calculate the normal (Press Esc to cancel)")
if not point:
break
# Calculate the normal vector at the selected point on the polysurface.
normal = rs.SurfaceNormal(polysurface_id, point[2])
if normal:
print("Normal vector at the selected point:", normal)
else:
print("Unable to calculate the normal vector.")
#- Prompt the user to select a polysurface.
polysurface_id = rs.GetObject("Select a polysurface", rs.filter.polysurface)
if polysurface_id:
error Message
Message: unable to convert 16c2377c-91b6-4c7b-9661-86b5ebaa6002 into Surface geometry
Traceback:
line 1026, in coercesurface, "C:\Users\jiny0\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\rhinoscript\utility.py"
line 2912, in SurfaceNormal, "C:\Users\jiny0\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\rhinoscript\surface.py"
line 11, in calculate_normal_at_points, "C:\Users\jiny0\AppData\Local\Temp\TempScript.py"
line 20, in <module>, "C:\Users\jiny0\AppData\Local\Temp\TempScript.py"
So, I changed the code from PolySurface to blep as follows.
But there’s another problem. Please help
Brep
def calculate_polysurface_normal(polysurface_id, point):
brep = rs.coercebrep(polysurface_id)
if brep:
cp_result = brep.ClosestPoint(point)
if cp_result[0]:
face_index = cp_result[1].FaceIndex
u, v = cp_result[2], cp_result[3]
face = brep.Faces[face_index]
normal = face.NormalAt(u, v)
return normal
return None
polysurface_id = rs.GetObject("select polysurface", rs.filter.polysurface)
if polysurface_id:
point = rs.GetPointOnSurface(polysurface_id, "point for noraml")
if point:
normal = calculate_polysurface_normal(polysurface_id, point)
if normal:
print("normalvector:", normal)
else:
print("can't")
print(normal)
Message: 'float' object has no attribute 'FaceIndex'
Traceback:
line 9, in calculate_polysurface_normal, "C:\Users\jiny0\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\LeoGem\brep .py"
line 20, in <module>, "C:\Users\jiny0\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\LeoGem\brep .py"
What should I fix
I’d appreciate it if you could tell me a better way than this
