Non uniform line thickness
Hello there
Is there a way in grasshopper or rhino for that matter to control the line weight (thickness)? In the attached image you see that the curve is bulging in the middle.
Thanks in advance,
There are many ways to do it
Make a pipe with a unique color and no shading. It could be more “light” to use a mesh pipe
You could make a surface (loft), I did that here
You can make a lot of dots of differents size
Variable offset (in Peacock plugin)
Variable Sweep in Heteroptera
You can also check Peacock Plugin which has a user-object to do that.
OffsetVariable_re.gh (62.3 KB)
Thank you both , the peacock algorithm seems to be doing the trick
