Rhino 6 seems to be missing the ability to have the blocks highlighted in the pre-selection mode (the drop down menu when there are multiple objects in close proximity). Standard objects work fine, it’s only blocks that are not highlighted. The issue makes it quite frustrating when working with a model with a lot of blocks.
Hi Vincent - I see that, thanks for the report.
https://mcneel.myjetbrains.com/youtrack/issue/RH-46723
Hi, yes
i confirme that, is it verry quite frustating
regards
