I have a problem. When i try to use the materials from the material gallery, it just shows the material as white, without any texture and it said there’s no picture loaded. I didn’t have this kind of problem before and I’m wondering if anyone knows how to fix it. Thank you!
Hi Natalija - can you please run SystemInfo
in Rhino and post the results? Can you also please post a screen shot of the problem?
And here you can see that all of the materials are white, even though they should be textured. It also says that there’s no image loaded but that has never happened to me before.
Hi Natalija - does it make any difference how the current renderer is set? (Render menu > Current renderer)
Try issuing the command _DownloadLibraryTextures
- it should get all textures for each material in the default material library.
It worked! Thank you so much!
