No control points on a scripted leader
There are a few topics on leader control points, but I don’t believe there is one that addresses this issue.
If I create a leader in a script, the resultant leader doesn’t display control points when you pick it. If you create a leader with Rhino’s leader command, you can see the control points. The script I used in the following video is from the help file:
Thanks,
Dan
Hi @DanBayn,
I’ve logged the issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-66094
– Dale
