EvoluteTools PRO is being used by the industry’s most reputable companies to turn high-end, breathtaking freeform designs into cost effective, real world structures faithful to the initial design intent. Award winning designs like KREOD, the highly prestigious Eiffel Tower Pavilions, the Baku Funicular stations, the Beaublanc Stadium or the CCV are just a few of the many projects made possible with EvoluteTools PRO.
Ever-growing, robust and versatile, the Rhino plugin now packs new features for your delight. 64 bit compatibility, cylinder fitting, developable lofting, panel repetition maximization and node axis optimization are just a few of the most requested functions made available now.
EvoluteTools PRO - Developable LoftingLofting of developable strip surfaces between pairs of curves.
EvoluteTools PRO - Panel fitting Approximation of surfaces with simplified surface types, e.g. cylinders, cones, and many more. Very extensive options exist.
EvoluteTools PRO - Panel repetition maximization Clustering of flat panels (triangles,quads,…), allowing to lower the number of unique panels, parts, etc.
EvoluteTools PRO - Mesh statistics Evaluating diverse criteria related to the buildability and cost of surfaces panelised using flat panels, e.g.: Angles between panels, corner angles of panels, node torsion, edge lengths, distance from a reference surface, (un)planarity of panels, etc. This module can easily be customised according to our customer’s requirements.
Posted Nov 11, 2013 by Carlos Perez on Rhino News, etc.
