How i can do this pattern on the roofs surfaces using Gh?
unnamed1.gh (11.0 KB)
Untitled1.3dm (891.7 KB)
My regards.
My regards.
Hello
what is your question ? It is not clear if you want to make this pattern with Grasshopper or you problem is just apply the pattern.
This pattern if from Expo 2020 Dubai UAE
https://www.expo2020dubai.com
https://www.bie-paris.org/site/fr/2020-dubai
If you want the logo in curve format, redo it with Rhinoceros or get in in vector format
If you want to apply of a surface, you be to be more specify, the simpliest way will be to apply it as a texture.
If not a texture, what do you want to do ?? Draw something to explain better
Not sure it is what you want
Here with morph
Thank you for replay .
I’m just need to apply that pattern on roofs surfaces, then Difference command to make a holes on roofs.
Also possible without deformation
So now you have everything to do it.But why using Grasshopper for that ? What are your parameters ?
Thank you sir.
