Need advice Wrap Grid component in Paneling Tool
Hi
I learn to use Paneling Tool model this
Attached file, page 11-14
I misunderstand about data structure after use Convert to Diamond Grid component.
Need advice to understand about Data Structure.
panelingtools4grasshopperprimer.pdf (8.0 MB)
Thank
Travis
@travis.designer.vn I’m not sure I understand your question. Do you like to understand what happen when the conversion to diamond grid happens? It basically rotate the data structure 45 degrees to allows for diagonal connections and fill some null points to complete the cells.
I hope this helps.
Hi @rajaa
Before
After
When using Extract Grid Indices in page 61, now I can see the change of data.
Your document’s very useful
Thank
by the way, could you please give me more explain to understand why we need to Wrap Grid.
I hope to understand data.
Thank
Each unit in the diamond grid extends more than one unit. Without wrapping the grid, you end up with the gap at the seam.
Does that help?
