Need advice to fix defect when use Morph3D
Hi
I use Paneling Tool for Grasshopper.
When I use Morph3D, there’s defect as below:
Need advice to fix it.
model02.zip (17.0 MB)
Thank
Travis
if “smooth morphing”, then the surfaces you want to smooth with need to be provided:
Thank @inno
It worked
Here’s a way I used to do what looks like a very similar result using only standard GH components:
model02-bb1.gh (63.1 KB)
Great job! Could you please give me advice to add thickness to this model in GH.
Thank
Travis
If you created this geometry in GH using loft, I’d just offset the original curves inside and loft them then you can connect the caps using “boundary surfaces”… this way you can avoid expensive operations like offsetsrf or offsetbrep + trimming and exlusion.
tay.0 is correct - That’s basically how I did it, but for a simple shape like this I found capping an offset and using SDiff was simpler to do. SDiff is slow with more complex shapes, so in that case tay.0’s method is better.
Screenshot_1
model02-bb2.gh (67.4 KB)
I try your suggestion:
model02-2.zip (17.3 MB)
May I did something wrong.
Thank
Travis
Hi
Oh I find out missing in Flatten and Graft Tree
It’s better. However I feel like something look overlap
Do you have any suggest.
model02-3.zip (17.3 MB)
Thank
Travis
Don’t overthink it, It is much simpler.
model02.gh (12.9 KB)
Your’re right :smile: thank alot
