Multithreading in Rhinocommon - Contour
is it possible to apply parallel computing in Rhinocommon and benefit from it using Brep.CreateContourCurves (with interval defined), or is it only possible for some custom loops?
Łukasz
Have you seen this Python parallel example:
import System.Threading.Tasks as tasks
import Rhino
import time, math
import scriptcontext
def radial_contour(brep, parallel, slice_count=360):
    """Generate series of curve slices through a brep by rotating a plane
    multiple times and intersecting that plane with the brep. This function
    demonstrates the use of .NET Parallel.For in order to run the function
    in parallel
    Parameters:
        brep = the Brep to contour
        parallel = If True, this function will compute intersections in multiple
          threads using Parallel.For. If False, all intersections will be performed
          on a single thread
        slice_count = number of slices to generate. Slices are evenly distributed
          over a full circle
    if not brep: return
    results = range(slice_count)
    rotation_axis = Rhino.Geometry.Vector3d(0,1,0)
    intersect_tol = scriptcontext.doc.ModelAbsoluteTolerance
    # local function that does the intersection work. This function is called
    # once for each angle in "slice_count" and needs to be thread-safe
    def slice_brep_at_angle(i):
        try:
            angle_rad = i/slice_count * 2.0 * math.pi
            plane = Rhino.Geometry.Plane.WorldXY
            plane.Rotate(angle_rad, rotation_axis, Rhino.Geometry.Point3d.Origin)
            rc, crvs, pts = Rhino.Geometry.Intersect.Intersection.BrepPlane(brep, plane, intersect_tol)
            if rc: results[i] = crvs
            else: results[i] = None
        except:
            pass
    if parallel:
        tasks.Parallel.ForEach(xrange(slice_count), slice_brep_at_angle)
    else:
        for i in xrange(slice_count): slice_brep_at_angle(i)
    return results
if __name__=="__main__":
    brep = rs.GetObject("Select Brep", rs.filter.polysurface)
    brep = rs.coercebrep(brep)
    if brep:
        # Make sure the Brep is not under the control of the document. This is
        # just done so we know we have a quick to access local copy of the brep
        # and nothing else can interfere while performing calculations
        brep.EnsurePrivateCopy()
        #run the function on a sinlge thread
        start = time.time()
        slices1 = radial_contour(brep, False)
        end = time.time()
        print "serial = ", end-start
        #run the function on mulitple threads
        start = time.time()
        slices2 = radial_contour(brep, True)
        end = time.time()
        print "parallel = ", end-start
        if slices2:
            for curveset in slices2:
                if curveset:
                    for curve in curveset: scriptcontext.doc.Objects.AddCurve(curve)
            scriptcontext.doc.Views.Redraw()
Thank you @Holo, I couldn’t find such example. I will check this.
I have created parallel contour function. Performance for large number of sections is increased by about 20% with 200 sections, and reduced by 20% for small number of sections for example 20. Since small number of sections gives still results fast enough, I will stick to code below. Maybe someone would suggest some changes below to make it faster. Tested on Win 10 with 8 core I7.
    public static Curve[] ParallelContourCurves(Brep brepToContour, Point3d contourStart, Point3d contourEnd, double interval)
        Vector3d normaldirection = new Vector3d(contourEnd - contourStart);
        double distance = normaldirection.Length;
        int numberofintersections = (int)(distance / Math.Abs(interval) + 1);
        Plane[] cuttingPlanes = new Plane[numberofintersections];
        Curve[] curves = null;
        Curve[][] tempcurves = new Curve[numberofintersections][];
        Point3d[][] temppoints = new Point3d[numberofintersections][];
        bool first = true;
        var rangePartitioner = Partitioner.Create(0, numberofintersections);
        Parallel.ForEach(rangePartitioner, new ParallelOptions { MaxDegreeOfParallelism = 2 }, (range, loopState) =>
            for (int i = range.Item1; i < range.Item2; i++)
                cuttingPlanes[i] = new Plane(contourStart, normaldirection);
                if (i == 0)
                    Rhino.Geometry.Intersect.Intersection.BrepPlane(brepToContour, cuttingPlanes[i], Tolerance, out tempcurves[i], out temppoints[i]);
                else
                    cuttingPlanes[i].Transform(Transform.Translation(normaldirection / (numberofintersections - 1) * i));
        foreach (Curve[] arrcurves in tempcurves)
            if (!first)
                curves = curves.Concat(arrcurves).ToArray();
            else
                curves = arrcurves;
                first = false;
        return curves;
I had hope to get something more, but it seems this task is not very suitable for parallel computing.
Why are you setting to max parallelism to 2?
Higher values corresponded to longer computation time. Its seems this is due overhead. Also without partitioning parallel computation is longer than existing contour function on my computer.
I have forgot Contour also has overload for single plane, so I have found it scales very well in parallel computing, opposite to intersection. Over 100% boost for 200 sections, and 30% boost for 20 sections. No partitioning is needed. Code below:
    public static Curve[] ParallelBrepContourCurves(Brep brepToContour, Point3d contourStart, Point3d contourEnd, double interval)
        bool first = true;
        Parallel.For(0, numberofintersections, i =>
            if (i == 0)
                tempcurves[i] = Brep.CreateContourCurves(brepToContour, cuttingPlanes[i]);
            else
            if (arrcurves != null)
                if (!first)
                else
                    curves = arrcurves;
                    first = false;
        return curves;
Boost is present even on only 2 cores so it is a sin to not do it. However I don’t know how it looks like on Mac.
I am happy now :slight_smile:
Holo
In my code I have millions of operations on:
for i in xrange(.....
Can I work in parallel?
My code results in a huge list.
I thought about slicing the list by the number of cores.
And then put it all together at the end.
I have found error in code due to bad conversion to int of number of sections. Number of sections now shall be calculated outside of this method. Fixed code below:
public static Curve[] ParallelBrepContourCurves(Brep brepToContour, Point3d contourStart, Point3d contourEnd, int numberOfIntersections)
	Vector3d normalDirection = new Vector3d(contourEnd - contourStart);
	double distance = normalDirection.Length;
	Plane[] cuttingPlanes = new Plane[numberOfIntersections];
	Curve[][] tempCurves = new Curve[numberOfIntersections][];
	bool first = true;
	Parallel.For(0, numberOfIntersections, i =>
		if (i == 0)
			tempCurves[i] = Brep.CreateContourCurves(brepToContour, cuttingPlanes[i]);
		else
			cuttingPlanes[i].Transform(Transform.Translation(normalDirection / (numberOfIntersections - 1) * i));
	foreach (Curve[] arrCurves in tempCurves)
		if (arrCurves != null)
			if (!first)
				curves = curves.Concat(arrCurves).ToArray();
			else
				curves = arrCurves;
				first = false;
	return curves;
