how can I multiply each item of each list on each branch of a tree with the relative same item of all the other branches of the same tree?
I can do it by using the nodes in the figure, but if the tree has variable branches I need to add branches manually to the node which I can not do for the algorithm I’m planning to make.
thanks Ric
could you please post an example file? not sure I have correctly understood what you’re trying to get
There is a duplicate data component found in the Sets tab.
Thanks for your answer, but I don’t think duplicate does what I’m looking for, but maybe you are right and I’m only overlooking something. Can you send me an example?
Oh that’s clever I would have never thought of that, thanks a lot!
Btw is there any tutorial or detailed documentation about tree data management? I sometimes struggle with selecting and or sorting tree branches in grasshopper.
Thank you very much!
