My first time posting here, apologies if the subject has been covered elsewhere, I have tried to find a solution!
I have a set of curves on a surface. I have divided each curve and moved the division points around to create vertices for rectangular frames.
I have a tree structure that has the curve at the first level, the number of divisions on each curve at second level and the frames as items at each division.
I want to loft the frames on each path (curve) individually. Since I only have 10 paths I have just split the tree 10 times, but I feel like there must be a better way that would allow me to introduce more curves later if I needed to.
Any suggestions?!
split tree problem.gh (31.1 KB)
