MRT Component Crash
This is my question.
a. Issue: When running the template file to calculate the annual UTCI, the software crashes during the MRT module calculation.
b. Screenshots
MRT component
Pop-up window during calculation
Rhino crash
c. Measures taken:
  1. Confirmed Radiance is installed in “C:\Program Files\Radiance.”
  2. Replaced Eddy3D with different versions (including 0.3.8.0, 0.4.1.0, 0.4.2.0).
  3. Replaced Radiance with different versions (including 5.4, 5.3).
    d. Grasshopper file (replaced the original template with the meteorological file).
    6_AnnualOutdoorComfort_1.gh (57.6 KB)
e. Version information: Windows 10, Rhino 7, Eddy3D 0.4.1.0, Radiance 5.4
Screenshots and the Grasshopper file have been attached.
i’ve the same problem did u solve it?
I’m sorry, I still couldn’t solve it in the end. Later, I attempted to use Ladybug for MRT calculations, Eddy3D for wind calculations,and then take the values with uniform grid points.
thank u i’ll try it
So sad to hear about this issue cannot be solved, i have struggled for this a whole day quq.
I will take a look at this over the winter break. Sorry for the issues you are facing.
Best,
Patrick
Hello Patrick, I’m appreciate that the issue has been solved after today i tried to simulate MRT component!
Best,
Lic
Hello Lic, May I ask how you resolved the issue? Was it fixed in Rhino 7? Looking forward to your reply~
Best regards,
Zsy
Hello Zsy, I’m sorry to tell you that this evening when i try to run MRT component again, the issue above is still persist, i don’t know why i could run it to calculate UTCI in this afternoon. According to the folder below, we can see that MRT component is still working at that time. Hope Patrick can help us to solve these issues :grinning:
Best,
Lic
Hello Lic, I’ve experienced a similar situation before—it worked once by chance but never again. It feels like a mystery!
