Hi, I am trying to copy a window using the movehole command and I keep getting “Boolean operation for hole making failed. Nothing done.” Any thoughts on why I get this error message?
Thanks Kevin
Hi Kevin - please post the object and indicate the start and end points of the move.
Right… I understand the concept; I need the geometry - the object in a Rhino file - to be able to help.
sorry
house.3dm (5.3 MB)
Kevin
Hi Kevin - thanks, I see MoveHole fails - you can, however Ctrl-Shift window select the window within the wall and Move or Gumball directly. I’ll see about the bug in the meantime.
https://mcneel.myjetbrains.com/youtrack/issue/RH-38128
Pascal
I did the Ctrl-shift window select (top left to bottom right), copy object in place, then gumball to move it to the right. It moved the entire window with mullions and panes, but the original window only kept the outer frame and trim.
When I Ctrl-shift window select, everything is highlighted. Why does only part of it get copied?
Kevin
Hi Kevin - Moving should work with my work-around, copying… not so much. In this case the simplest is probabaly
ExtractSrf > Copy=YesJoin the resultsMove to where you like.DupBorderTrim the wall with the border curve.Join it all back.-Pascal
Thank you, it took a couple of tries but it worked. Any idea why the movehole does not work in this instance, but works on the “A simple building” tutorial on the rhino web page?
Hi Kevin - it looks like a bug to me - I added a bug to our system - linked in a post above.
I may have found another bug related to moving holes - the hole takes unrelated geometry with it when it moves. Has anyone else experienced this? Should this also be fixed? I tested in both v7 and v8 and the glitch is in both.
@cody.winchester best would be is you could share that file before the move
After rebooting my system and restarting Rhino (v8) this morning, I attempted to make another recording showing what I tried yesterday with building up geometry from scratch and going through the MakeHole, MoveHole operations. Instead this time, it worked as expected. For some reason, Rhino was experiencing a temporary glitch when attempting the exact same set of operations yesterday. I tried recreating the steps with the geometry I worked with in the recording I posted yesterday and it too worked as expected. Something strange is going on under the hood. For now this issue appears to have resolved itself. Perhaps Rhino ran out of memory or some other effect of running for long period of time that led to the hiccup. If it happens again I will post the file and a recording again here. I appreciate your reply!
