Often when I’m creating a larger drawing set for a project, I have a few files with layouts that eventually get printed to several pdfs, which are then concatenated into one. Page numbers need to line up across the packet. I’m already using Document user text and various text functions including the page number function. However I was thinking it would be nice to use an arbitrary offset value in an evaluated equation to calculate the page numbers.
This had me thinking, what if there was a way to generally evaluate mathematical or pythonic equations to generate text objects? It could be possible with a script that finds the text objects via user attributes, evaluates and updates them but this would be clunky.
I’m imagining an expression evaluator like in the vscode python debug console.
Indexing arrays, dicts, using math, f-strings etc.
I’m aware of this offset but I was thinking of a global offset that one could change and all instances of the text that used that value would change…?
Can you give an example of regex or python evaluation in the text field?
Thanks,
T
My comment about regex was mainly because I thought you might have tons of files with meaningfully concatenated file names and now you need to extract and join some of them. If that was the case, you could use regex patterns to filter a selection of files.
Just want to bring everybody’s attention to the possibilities of conditional manipulations in Text.
This is an example of using the IF-ELSE statement (recursive even) which works for me in a block’s texts. It automatically calculates the tolerance based on the tape length from UserText and outputs the amount.
Even though it wasn’t documented anywhere it is working perfectly (as a part of python).
%<'1.0' if int(UserText("block", "Length", "Length", "100"))<200 else ('3.0' if int(UserText("block", "Length", "Length", "100"))>601 else (int(UserText("block", "Length", "Length", "100"))*0.005)) >%
