C:\Users\tonyl\anaconda3\python.exe C:/Users/tonyl/PycharmProjects/pythonProject6/main.py
Traceback (most recent call last):
File “C:\Users\tonyl\PycharmProjects\pythonProject6\main.py”, line 2, in
import Eto.Drawing as drawing
ModuleNotFoundError: No module named ‘Eto’
The module is not ETo, but Eto.Forms. This is a .NET GUI library. The Eto-stubs are supposed to help here, but to be honest I haven’t used these to be able to tell you how it is supposed to work. This project is from GitHub - mcneel/pythonstubs: Python stubs for .NET assemblies and is created by @stevebaer
Depends on what you are trying to do. Perhaps you can explain.
Python scripts using Rhino and Eto.Forms are intended to run in Rhino, and at least untit Rhino 7 that is all Python 2.7 level, for instance using _EditPythonScript or via a toolbar button. Rhino 8 will bring Python 3.x integration via _RhinoCode.
Typically you don’t run these scripts outside Rhino.
At most you can use Rhino Inside CPython, but that still requires a licensed Rhino installation to work on the machine you intend to run your scripts on.
