I’m looking to modify a script that performs a Game of Life function on a number of cells in order to generate a 3-Dimensional Volume. Currently the input values for the cells are randomized, but I would like to have direct control over these inputs. Is it possible to set these values either manually, or based on values from a black and white image (a la the grasshopper image sampler)? Because these arrays are often 20x20, I would prefer the latter.
Any help would be greatly appreciated. Thanks!
I only included the portion of the script that seemed relevant, if you need more information I would be happy include it.
def randomizeArray(intLength,intWidth):
arr = []
for j in range(intWidth):
arri = []
for i in range(intLength):
rnd = random.random()
arri.append(rnd)
arr.append(arri)
return arr
def Main():
intLength = rs.GetInteger("how many in x",30)
intWidth = rs.GetInteger("how many in y",30)
intGen = rs.GetInteger("how many generations",60)
strStack = rs.GetString ("should I stack the generations", "yes", ["yes", "no"])
crvs = rs.GetObjects("select the crvs",4)
thres = rs.GetReal("type the threshold to voxelize",1)
allValues = []
arrValues = randomizeArray(intLength,intWidth)
for i in range(100):
arrValues = applyGOL(arrValues)
allValues.append(arrValues)
#arrMeshes = render(arrValues,-1, strStack)
for i in range(intGen-1):
arrValues = applyGOLCrvs(arrValues, i, crvs)
if strStack == "no" :
update(arrMeshes, arrValues)
else :
render(arrValues,i, strStack)
myVoxels = voxels(intLength,intWidth,intGen, allValues)
myVoxels.voxelize(thres)
#Call DeleteObjects2dArray(arrMeshes)
Main()
