Modify tags' instance parameter
Hi all,
I am annotating material code for a linked dwg file. The material tag is fake, it doesn’t actually tie to model. So the Material code(Finishes) and the Description are instance parameters.
Since the design changed, I need to change the material codes and descriptions.
I wonder if there is a way I can use RIR to find and select all the same tags (tags have the same instance parameter value) to modify them in one go?
Many thanks
Here is an example of creating a Parameter Filter combined with a Type Filter to get specific elements.
r2024-paramterFilterexample.rvt (5.7 MB)
R8-RiR-ParameterTypeFilter.gh (19.6 KB)
Cool~ it looks a bit complicated to me… I will try to understand it.
Many thanks!
