Hi all,
We have two lists of points with identical lengths.
For each point in List1, I want my code to search for the closest point in List2.
Once a point is selected from List2, it no longer can be picked by other points of List1.
My code generates 6 lines instead of 3.
I know List2 has to be updated in one way or another.
Appreciate it if someone highlights what I am doing wrong in my code,
@Dancergraham
Hi Graham,
Unindenting those lines does not help, whereas it says " index out of range" when moving the points.
Also, the link you provided, finds the closest point but does not knock it off the List2 after assignment.
As a result, one point in List2 can be assigned to multiple points in List1.
import Rhino.Geometry as rg
def point_closest_point(pt, pts_list):
"""Finds the closest point in a collection of points.
Args:
pt (Rhino.Geometry.Point3d): A point to search from.
pts_list (list): A collection of points to search.
Returns:
The closest point.
closest_dist = float("inf") # infinity
closest_idx = -1
for i in xrange(len(pts_list)):
dist = pt.DistanceTo(pts_list[i])
if dist < closest_dist:
closest_dist = dist
closest_idx = i
if closest_idx >= 0:
return closest_idx
y_pts = y[::] # temporary list
lines = []
for i in range(len(x)):
closest_idx = point_closest_point(x[i], y_pts)
lines.append(rg.Line(x[i], y_pts[closest_idx]))
y_pts.pop(closest_idx)
a = lines
