MissingMemberException: 'Rhino.Geometry' object has no attribute 'Rhino'
hey so i try to run this code but get always an error, the code is below and i tried changing line 24 to something else like : radians = angle * math.pi / 180 or import math then radians = math.radians(angle) but none of it works, i also tried in both rhino 7 and 8 same error:
import Rhino
Define circle parameters
radius = 5.0 # meters
num_pillars = 10
Calculate angular spacing
angle_spacing = 360.0 / num_pillars
Function to create a pillar object at a specific location
def create_pillar(x, y, height):
pt = Rhino.Geometry.Point3d(x, y, 0.0)
circle = Rhino.Geometry.Circle(pt, radius)
cylinder = Rhino.Geometry.Cylinder(circle, height)
rs.AddObject(cylinder)
Loop to place pillars
for i in range(num_pillars):
# Calculate angle for current pillar position
angle = i * angle_spacing
# Convert angle to radians for trigonometric functions
radians = Rhino.Geometry.DegreesToRadians(angle)
# Calculate x and y coordinates based on radius and angle
x = radius * math.cos(radians)
y = radius * math.sin(radians)
# Create the pillar object
create_pillar(x, y, 2.0)  # Adjust height as needed
Print completion message
print(“Created”, num_pillars, “pillars in a circular arrangement.”)
This might help (not how I would go about this, just trying to patch your code).
import Rhino
import math
cylinders = []
# Define circle parameters
num_pillars = 10
# Calculate angular spacing
# Function to create a pillar object at a specific location
    cylinders.Add(cylinder)
# Loop to place pillars
    radians = Rhino.RhinoMath.ToRadians(angle)
a = cylinders
240317a_python_exception.gh (5.7 KB)
-Kevin
thanks but what was the problem, could you tell me what the problem and what the solution is
Put your code in a GhPython Script component:
There is no Rhino.Geometry.DegreesToRadians() function.
Replaced line 28 with:
Next error:
You are calling functions from the math module and you have not imported it.
Added line 3:
import math
Next error:
There is no rs.AddObject() function.
When working with GhPython, I prefer using RhinoCommon to RhinoScript.
Added an array definition on line 5:
cylinders = []
Changed line 22 to:
Added line 40 to assign the cylinders array to script output a:
a = cylinders
No longer using rhinoscriptsyntax so don’t need to import it (deleted line 2).
Final working code:
Here’s the code in the 4 states shown above:
240318a_python_exception.gh (11.8 KB)
To post properly formatted code in the forum, insert this line before your code:
format_tag1
And insert this line after your code:
format_tag2
Also helpful if you upload a python or grasshopper file with your post.
-Kevin
