hi all,
i was using vray to render and it worked fine - then i closed the file and reopened it later to do some more rendering but ever since then I cant get v-ray to render properly. the render is always misaligned from the viewport, nothing changes when i change the aspect ratio. additionally, the v-ray assets do not show up at all in the renders and some of my own model seems to be missing in the render. additionally, at high rendering output i am still getting poor results. i am unsure what could be causing this since i did not change my model from when i used it prior, except for adding a couple more vray assets into the model, but i have made sure to:
- check if vray is my current renderer
- vertical lens tilt = 0
- model basepoint is at 0,0,0
I am on rhino 8
images below:
thank you in advance
