@lowell You seem to be the dimension programming guru, does the explanation of this problem make sense to you? I was discussing this with pascal in another thread, but it got kind of fuzzy.
@donl517 -
After you pick the point for where you’re dimensioning, look at the command line and set KinkOffset to something like 0.01 then pick a point for the end of the dimension.
That will stick for the session, but not between sessions. I’m not really sure how that should work.
It looks like it starts out way too big. I don’t remember just how that gets set, but I’ll see what I can do about it. Maybe starting with your extension offset would work.
Any other suggestions are welcome.
I agree about that.
I was just telling you what you could do for now until I change something.
It could have been part of a dimstyle, but that’s pretty hard to change at this stage.
I’ll change it to start out pretty small and save it between sessions.
If that works for you, great. If not we can revisit it
