Hi All!
How to get rid of mesh inter collisions in Kangaroo simulation if I need to create cloth or something?..
Couldn’t find the tool for that.
Check out the clothcollide file here:
(You might need to delete the Grab component and replace it with a new one from the toolbar, then you should be able to drag points in the rhino view)
This uses spheres centred at each mesh vertex. Their radius should be set at around the mesh edge length
Wow! Thank You So Much! So many interesting things up there!
