Mesh plane section
Hi
I have a question about the section tool that gives the section of a mesh with a plane. I want to slice a brep (made in rhino) into slices. It works, but I get more points than I expected and I don’t know where they come from. I thought I would only see the control points (so the outer points of each box, but there are some points in between too. Anyone knows where those come from?
Rhino- and grasshopperfile can be found as attachment.
Kind regards
Reinout
Fout punten.gh (10.4 KB)
Verdelingen.3dm (114.2 KB)
Hi.
If you convert your referenced brep to mesh using Mesh Brep, then as you can see, you’ll probably get a mesh with additional interior edges which are the cause of additional kink points.
Try to use BBX instead…
Fout punten_re.gh (22.2 KB)
Or add Simplify Curve
Fout punten_reV2.gh (18.9 KB)
