Would it be possible to allow 0 as a Density input for the Mesh from SubD component?
Just like in Weaverbird components, 0 would not do anything and return the original mesh.
Currently you can connect a SubD directly to a ‘Mesh’ parameter component to extract the original control polygon
Agreed though, this isn’t obvious and having D=0 on the MeshFromSubD component do the same would be more consistent.
Thanks Daniel I’m aware of that.
My issue is mainly that sometimes I’m not sure if I want subdivision or not. Therefore it would be convenient to be able to set the density to 0.
