I ran into a problem with the Mesh Curve intersection component, where it fails to compute some mesh-curves intersections.
It looks like the problem has to do with circles because if they are rebuilt or converted into polylines then the intersections are computed correctly.
I’m attaching an example with the problem.
I tested the same definition in Rhino 6 and it works there.
Actually the problem is due to the crv start being on the mesh. I had tested a different seam, but without thinking I entered 0.5 as new parameter which rotated the seam by 180° so the circle start pt was always on the mesh.
If the seam pt is different the intersections are found correctly.
Actually the points that are shown in your screenshot are two distinct points (very close to each other). When the circle start pt is on the mesh then the component just fails to return any intersection.
But this is more understandable as many intersection operations have problems with overlapping / coincident parts.
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 (NVidia) Memory: 8GB, Driver date: 10-13-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.39
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: NA
Driver Version: NA
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\marco\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
I found out that the problem only occurs with smaller tolerances (0.0001 mm instead of 0.001). In that case when the seam point is on the mesh the intersection is failing (while if the seam is elsewhere it works).
That’s possibly true but pretty much everything with mesh intersections has undergone many changes since then because there were too many cases where those fail in Rhino 6.
