hey, I’m new to grasshopper and I’m trying to create lines between points A and B that are located on the same line so I can know the distance of every lines, any help really appreciated !
I tried this but I want to connect only point with the same y value and I really don’t know how to do it ;(
Is there a way to create lines between the 2 points on the same line from the line SDL?
yes, just replace the distance component with line component (line between 2 points)
already tried it but it connects every points together, not only the once that are aligned with the line SDL (3rd photo shows how it connects) but thanks tho for helping me
These lines go from inside to the surface. If you want lines from outside points to the surface. a change is needed…
line to human face_2020Dec3a.gh (56.3 KB)
P.S. Two changes…
line to human face_2020Dec3b.gh (56.7 KB)
NOTE: I should have deleted the Mesh | Curve component.
Thanks a lot ! that’s exactly what I’ve been trying to do for hours The first solution was the one I was looking for.I appreciate it :))
Have you seen this? Pretty cool.
3D Face Reconstruction from a Single Image
This is an online demo of our paper Large Pose 3D Face Reconstruction from a Single Image via Direct Volumetric CNN Regression . Take a look at our project website to read the paper and get the code.
Please use a (close to) frontal image, or the face detector won’t see you (dlib). Images and 3D reconstructions will be deleted within 2 days, but may still exist in our backups for up to 2 weeks. Your photos will not be used for anything other than this demo.
1,458,597 faces uploaded and 3,470,223 model views since 7th of September 2017.
