I am unable to measure a diameter of a solid object or determine its volume in mm^3. How might i do this?
You can measure radius of something like a sphere with the Radius command. Radius only works on curves, so you need to find a seam edge to measure. You could also measure diameter with the Distance command and the appropriate object snaps.
The Volume command will allow you to measure volumes of closed objects; if you run the command without objects pre-selected, you will see options for different unit reporting. Objects must be closed in order for this to work.
HTH, --Mitch
And the result shows up in command history.
Yes, thanks for adding that, on Mac, the panel for the results is so small, people often miss it…
–Mitch
