Measure interior angles of a polyline and cull segments
Hello All,
I’m trying to write a script that will measure the interior angles of a polyline, here’s what I got so far: (combined some scripts I found on the forum)
as you see it’s measuring some of the exterior angles at the moment:
but I need to get these instead:
Then, I need to sort these curves. The ones with the interior angle that is more than 180 will be in a different group (highlihgted with red and blue here)
here’s the GH file with internalised data:
interior angles.gh (11.3 KB)
Thank you!
Renan
I knew I had this one before !
Check this as well.
interior angles_re.gh (13.5 KB)
Hi Kim, you can make it simpler
This is great, Thanks so much all!
Hi anon, can you please tell the name of the last component.
It’s called Arc Dimension.
