Math Sequence/ Loop?
Hello everyone, I am trying to have simple Math equation in GH and then take the result and run the same equation on it. Example:
1+ (item1 on the list/2) = Result1
Result1+ (item2 on the list/2) = Result2
Result2+ (item2 on the list/2) = Result3
and so on about a 1000 times. I think I can use Anemone but I have no experience with it and I’m not understanding the gist of it yet. Can you guys please confirm that Anemone can do this? Where can I find more examples? (the link from website doesn’t work)
You can achieve similar result by using native grasshopper components.
Sarkaharrington.gh (17.3 KB)
If you prefer using anemone, here is the definition:
Sarkaharrington.gh (19.1 KB)
Is there a component that would do “MassSubstraction”? :slight_smile:
Where did you count in the number one from my definition?
I would like to see how to change it to any other number, e.g. 0. Thank you so much for your response, I am still trying to understand the Anemone script
Since subtraction isn’t commutative, I decided against it. You could do it yourself by formatting the data using hyphens as separators:
Thanks David,
that’s clever. Is there a way how to get the partial result as in Mass Addition as well?
Method 1:
Sharky.gh (16.7 KB)
Method 2:
Sharky.gh (15.6 KB)
In that case you could flip the signs of all values except the first and just use Mass Addition.
Nice! I need to look into this more. Out of curiosity, how would you do this?
2 * ListItem1 - 0 = Result1
2 * ListItem2 - Result1 = Result2
2 * ListItem3 - Result2 = Result3
Sharky.gh (15.6 KB)
Pufferfish has a Mass Subtraction and Mass Division components.
