Hi all . In this video you can see what happens. i have 2 files in my desktop : boh.3dm and mah.3dm with embedded folders. One file with just a sphere and one with a cube .I import one in the other and Rhino puts all the materials of the imported file in the desktop. Is it a bug?
Fixing this now. Just to be clear, the correct behavior is that the mah.3dm embedded files will actually end up in boh/embedded_files - because once the import has taken place, the content is now actually in boh.3dm.
If you want the files to be unpacked into moh/embedded_files, just open moh.3dm…although this won’t actually cause the folder to be created after you’ve done the import because the files will be found just fine.
