Mapping points to surface
Alright, so I’m trying to map boids on a surface to make a flocking behavior on a surface for my new plugin
(based on long Nguyen’s workshop)
My approach was to convert positions to UV parameters by remapping x,y values of points in 2d to surface domain in U and V.
It doesn’t give the desired effect can anyone help me with this ?
thanks.
here is the code
using System;
using System.Collections.Generic;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Types;
using Rhino.Geometry;
namespace SurfaceTrails2.FlockingMapToSurface
public class GhcFlockingSimulation : GH_Component
private FlockSystem flockSystem;
    public GhcFlockingSimulation()
        : base(
              "Flocking Map To Surface",
              "FlockingMapToSurface",
              "YFAtools",
              "AgentBased")
    protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
        pManager.AddBooleanParameter("Reset", "Reset", "Reset", GH_ParamAccess.item, false);
        pManager.AddBooleanParameter("Play", "Play", "Play", GH_ParamAccess.item, false);
        pManager.AddBooleanParameter("3D", "3D", "3D", GH_ParamAccess.item, true);
        pManager.AddSurfaceParameter("srf", "srf", "srf", GH_ParamAccess.item);
        pManager.AddIntegerParameter("Count", "Count", "Number of Agents", GH_ParamAccess.item, 50);
        pManager.AddNumberParameter("Timestep", "Timestep", "Timestep", GH_ParamAccess.item, 0.02);
        pManager.AddNumberParameter("Neighbourhood Radius", "Neighbourhood Radius", "Neighbourhood Radius", GH_ParamAccess.item, 3.5);
        pManager.AddNumberParameter("Alignment", "Alignment", "Alignment", GH_ParamAccess.item, 0.5);
        pManager.AddNumberParameter("Cohesion", "Cohesion", "Cohesion", GH_ParamAccess.item, 0.5);
        pManager.AddNumberParameter("Separation", "Separation", "Separation", GH_ParamAccess.item, 0.5);
        pManager.AddNumberParameter("Separation Distance", "Separation Distance", "Separation Distance", GH_ParamAccess.item, 1.5);
        pManager.AddCircleParameter("Repellers", "Repellers", "Repellers", GH_ParamAccess.list);
        pManager[10].Optional = true;
        pManager.AddBooleanParameter("Use Parallel", "Use Parallel", "Use Parallel", GH_ParamAccess.item, false);
        pManager.AddBooleanParameter("Use R-Tree", "Use R-Tree", "Use R-Tree", GH_ParamAccess.item, false);
    protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
        pManager.AddTextParameter("Info", "Info", "Information", GH_ParamAccess.item);
        pManager.AddPointParameter("Positions", "Positions", "The agent positions", GH_ParamAccess.list);
        pManager.AddVectorParameter("Velocities", "Velocities", "The agent veloctiies", GH_ParamAccess.list);
    protected override void SolveInstance(IGH_DataAccess DA)
        // Read input parameters
        bool iReset = true;
        bool iPlay = false;
        bool i3D = false;
        Surface baseSurface = null;
        int iCount = 0;
        double iTimestep = 0.0;
        double iNeighbourhoodRadius = 0.0;
        double iAlignment = 0.0;
        double iCohesion = 0.0;
        double iSeparation = 0.0;
        double iSeparationDistance = 0.0;
        List<Circle> iRepellers = new List<Circle>();
        bool iUseParallel = false;
        bool iUseRTree = false;
        DA.GetData("Reset", ref iReset);
        DA.GetData("Play", ref iPlay);
        DA.GetData("3D", ref i3D);
        DA.GetData("srf", ref baseSurface);
        DA.GetData("Count", ref iCount);
        DA.GetData("Timestep", ref iTimestep);
        DA.GetData("Neighbourhood Radius", ref iNeighbourhoodRadius);
        DA.GetData("Alignment", ref iAlignment);
        DA.GetData("Cohesion", ref iCohesion);
        DA.GetData("Separation", ref iSeparation);
        DA.GetData("Separation Distance", ref iSeparationDistance);
        DA.GetDataList("Repellers", iRepellers);
        DA.GetData("Use Parallel", ref iUseParallel);
        DA.GetData("Use R-Tree", ref iUseRTree);
        if (iReset || flockSystem == null)
            flockSystem = new FlockSystem(iCount, i3D);
        else
            // Assign the input parameters to the corresponding variables in the  "flockSystem" object
            flockSystem.Timestep = iTimestep;
            flockSystem.NeighbourhoodRadius = iNeighbourhoodRadius;
            flockSystem.AlignmentStrength = iAlignment;
            flockSystem.CohesionStrength = iCohesion;
            flockSystem.SeparationStrength = iSeparation;
            flockSystem.SeparationDistance = iSeparationDistance;
            flockSystem.Repellers = iRepellers;
            flockSystem.UseParallel = iUseParallel;
            // Update the flock
            if (iUseRTree)
                flockSystem.UpdateUsingRTree();
            else
                flockSystem.Update();
            if (iPlay) ExpireSolution(true);
        // Output the agent positions and velocities so we can see them on display
        List<GH_Point> positions = new List<GH_Point>();
        List<GH_Vector> velocities = new List<GH_Vector>();
        List<GH_Point> surfacePositions = new List<GH_Point>();
        var surface = baseSurface.ToNurbsSurface();
        foreach (FlockAgent agent in flockSystem.Agents)
            positions.Add(new GH_Point(agent.Position));
            velocities.Add(new GH_Vector(agent.Velocity));
            // Position on surface
            Interval u = new Interval(0, 1);
            Interval v = new Interval(0, 1);
            surface.SetDomain(0, u);
            surface.SetDomain(1, v);
            var remappedU = NumberOperations.remap(0,1,surface.Domain(0).T0,surface.Domain(0).T1,agent.Position.X);
            var remappedV = NumberOperations.remap(0,1,surface.Domain(1).T0,surface.Domain(1).T1,agent.Position.Y);
            surfacePositions.Add(new GH_Point(surface.PointAt(remappedU, remappedV)/*surface.PointAt(agent.Position.X, agent.Position.Y*/));
        DA.SetDataList("Positions", surfacePositions);
        DA.SetDataList("Velocities", velocities);
    protected override System.Drawing.Bitmap Icon { get { return Properties.Resources._28_8_18_FlockSimulation; } }
    public override Guid ComponentGuid { get { return new Guid("7066d2ac-3c0a-47db-b22f-4d8c25bf8baa"); } }
using System;
using System.Threading.Tasks;
public class FlockSystem
public List Agents;
    public double Timestep;
    public double NeighbourhoodRadius;
    public double AlignmentStrength;
    public double CohesionStrength;
    public double SeparationStrength;
    public double SeparationDistance;
    public List<Circle> Repellers;
    public bool UseParallel;
    public FlockSystem(int agentCount, bool is3D)
        Agents = new List<FlockAgent>();
        if (is3D)
            for (int i = 0; i < agentCount; i++)
                FlockAgent agent = new FlockAgent(
                    Util.GetRandomPoint(0.0, 30.0, 0.0, 30.0, 0.0, 30.0),
                    Util.GetRandomUnitVector() * 4.0);
                agent.FlockSystem = this;
                Agents.Add(agent);
        else
                    Util.GetRandomPoint(0.0, 30.0, 0.0, 30.0, 0.0, 0.0),
                    Util.GetRandomUnitVectorXY() * 4.0);
                Agents.Add(agent);
    private List<FlockAgent> FindNeighbours(FlockAgent agent)
        List<FlockAgent> neighbours = new List<FlockAgent>();
        foreach (FlockAgent neighbour in Agents)
            if (neighbour != agent && neighbour.Position.DistanceTo(agent.Position) < NeighbourhoodRadius)
                neighbours.Add(neighbour);
        return neighbours;
    private void ComputeAgentDesiredVelocity(FlockAgent agent)
        List<FlockAgent> neighbours = FindNeighbours(agent);
        agent.ComputeDesiredVelocity(neighbours);
    public void Update()
        if (UseParallel)
            Parallel.ForEach(Agents, ComputeAgentDesiredVelocity);
        else
            foreach (FlockAgent agent in Agents)
                ComputeAgentDesiredVelocity(agent);
        // Once the desired velocity for each agent has been computed, we update each position and velocity
            agent.UpdateVelocityAndPosition();
    public void UpdateUsingRTree()
        /* First, build the R-Tree */
        RTree rTree = new RTree();
        for (int i = 0; i < Agents.Count; i++)
            rTree.Insert(Agents[i].Position, i);
        /* Then, we use the R-Tree to find the neighbours
            and compute the desired velocity */
            EventHandler<RTreeEventArgs> rTreeCallback =
            (object sender, RTreeEventArgs args) =>
                if (Agents[args.Id] != agent)
                    neighbours.Add(Agents[args.Id]);
            rTree.Search(new Sphere(agent.Position, NeighbourhoodRadius), rTreeCallback);
        // Once the desired velocity for each agent has been computed, we can update each position and velocity
        foreach (FlockAgent agent in Agents) agent.UpdateVelocityAndPosition();
public class FlockAgent
public Point3d Position;
public Vector3d Velocity;
    public FlockSystem FlockSystem;
    private Vector3d desiredVelocity;
  private  double boundingBoxSize = 1;
    public double BoundingBox
        get { return boundingBoxSize;} set { boundingBoxSize=value; } }
    public FlockAgent(Point3d position, Vector3d velocity)
        Position = position;
        Velocity = velocity;
    public void UpdateVelocityAndPosition()
        Velocity = 0.97 * Velocity + 0.03 * desiredVelocity;
        if (Velocity.Length > 8.0) Velocity *= 8.0 / Velocity.Length;
        else if (Velocity.Length < 4.0) Velocity *= 4.0 / Velocity.Length;
        Position += Velocity * FlockSystem.Timestep;
    public void ComputeDesiredVelocity(List<FlockAgent> neighbours)
        // First, reset the desired velocity to 0
        desiredVelocity = new Vector3d(0.0, 0.0, 0.0);
        // Pull the agent back if it gets out of the bounding box
        if (Position.X < 0.0)
            desiredVelocity += new Vector3d(-Position.X, 0.0, 0.0);
        else if (Position.X > boundingBoxSize)
            desiredVelocity += new Vector3d(boundingBoxSize - Position.X, 0.0, 0.0);
        if (Position.Y < 0.0)
            desiredVelocity += new Vector3d(0.0, -Position.Y, 0.0);
        else if (Position.Y > boundingBoxSize)
            desiredVelocity += new Vector3d(0.0, boundingBoxSize - Position.Y, 0.0);
        if (Position.Z < 0.0)
            desiredVelocity += new Vector3d(0.0, 0.0, -Position.Z);
        else if (Position.Z > boundingBoxSize)
            desiredVelocity += new Vector3d(0.0, 0.0, boundingBoxSize - Position.Z);
        // If there are no neighbours nearby, the agent will maintain its veloctiy,
        // else it will perform the "alignment", "cohension" and "separation" behaviours
        if (neighbours.Count == 0)
            desiredVelocity += Velocity; // maintain the current velocity
        else
            // "Alignment" behavior
            Vector3d alignment = Vector3d.Zero;
            foreach (FlockAgent neighbour in neighbours)
                alignment += neighbour.Velocity;
            // We divide by the number of neighbours to actually get their average velocity
            alignment /= neighbours.Count;
            desiredVelocity += FlockSystem.AlignmentStrength * alignment;
            // "Cohesion" behavior
            Point3d centre = Point3d.Origin;
                centre += neighbour.Position;
            // We divide by the number of neighbours to actually get their centre of mass
            centre /= neighbours.Count;
            Vector3d cohesion = centre - Position;
            desiredVelocity += FlockSystem.CohesionStrength * cohesion;
            // "Separation" behavior
            Vector3d separation = Vector3d.Zero;
                double distanceToNeighbour = Position.DistanceTo(neighbour.Position);
                if (distanceToNeighbour < FlockSystem.SeparationDistance)
                    Vector3d getAway = Position - neighbour.Position;
                    /* We scale the getAway vector by inverse of distanceToNeighbour to make
                       the getAway vector bigger as the agent gets closer to its neighbour */
                    separation += getAway / (getAway.Length * distanceToNeighbour);
            desiredVelocity += FlockSystem.SeparationStrength * separation;
        // Avoiding the obstacles (repellers)
        foreach (Circle repeller in FlockSystem.Repellers)
            double distanceToRepeller = Position.DistanceTo(repeller.Center);
            Vector3d repulsion = Position - repeller.Center;
            // Repulstion gets stronger as the agent gets closer to the repeller
            repulsion /= (repulsion.Length * distanceToRepeller);
            // Repulsion strength is also proportional to the radius of the repeller circle/sphere
            // This allows the user to tweak the repulsion strength by tweaking the radius
            repulsion *= 30.0 * repeller.Radius;
            desiredVelocity += repulsion;
I assume your system operates in 2d and you want to map it to a surface, instead of operating directly on the surface (which works better).
You need to normalize the surface and the position of the boids, so both systems are using the same space. You’ve normalized the surface, but I don’t know if you’ve normalized the position. For this, if the region is from x0 to x1 and y0 to y1, and the position is x,y, the normalized position will be:
nx = (x-x0)/(x1-x0);
ny = (y-y0)/y1-y0);
then with nx,ny you can place it on the normalized surface.
Two considerations, 1. if the surface is trimmed surface, it is possible that the position will come out of the visible surface. 2. Before I mentioned that it works best to operate directly on the surface, because if you treat this rule (pull to the surface) as a restriction rather than a force, you can for example, make the velocity always tangential to the surface, or project the position to the surface after updating it. It depends on how you have implemented the force system (I haven’t stopped to look at the whole code), but it’s not a big deal either, maybe it’s just my preference.
to be honest I tried a similar approach by using u,v coordinates instead of points but I failed horrible. so I thought I 'll just map them to the surface in my v1.0 and then build up the complexity.
I will try your current solution ahead and later I’ll be posting my V2 here.
@Dani_Abalde your solution worked great.
now I’m making v2 to make it operate directly on the surface.
it doesn’t seem to work at all. can you tell me what I’m missing here ?
using System;
namespace SurfaceTrails2.FlockingOnSrf
public List Agents;
     NurbsSurface _surface;
    private double _boundingBoxSize = 1;
    private Random _randomX = new Random();
    private Random _randomY = new Random();
    public double BoundingBox { get { return _boundingBoxSize; } set { _boundingBoxSize = value; } }
    public NurbsSurface Surface { get { return _surface; } set { _surface = value; } }
    public FlockSystem(int agentCount/*, bool is3D*/,NurbsSurface surface)
        Surface = surface;
        Random random = new Random();
        Interval domainU = _surface.Domain(0);
        Interval domainV = _surface.Domain(1);
        _surface.Domain(0);
        _surface.Domain(1);
        _surface.SetDomain(0, domainU);
        _surface.SetDomain(0, domainV);
        double randomCoordinateX = _randomX.NextDouble();
        double randomCoordinateY = _randomX.NextDouble();
        _surface.Domain(0);
        _surface.Domain(1);
        var tu = domainU.ParameterAt(random.NextDouble());
        var tv = domainV.ParameterAt(random.NextDouble());
        var vectorX = _surface.PointAt(Util.GetRandomUnitVectorX(), Util.GetRandomUnitVectorY()).X;
        var vectory = _surface.PointAt(Util.GetRandomUnitVectorX(), Util.GetRandomUnitVectorY()).Y;
        //if (is3D)
        //    for (int i = 0; i < agentCount; i++)
        //        FlockAgent agent = new FlockAgent(
        //            Util.GetRandomPoint(0.0, 30.0, 0.0, 30.0, 0.0, 30.0),
        //            Util.GetRandomUnitVector() * 4.0);
        //        agent.FlockSystem = this;
        //        Agents.Add(agent);
        //else
                    _surface.PointAt(_randomX.NextDouble(), random.NextDouble()),
                   Util.GetRandomUnitVectorXY() * 0.2667 *BoundingBox);
                Agents.Add(agent);
        var neighbours = new List<FlockAgent>();
        return neighbours;
        if (UseParallel)
        else
            foreach (var agent in Agents)
        var rTree = new RTree();
        for (var i = 0; i < Agents.Count; i++)
        double maxVelocity = 0.2667 * FlockSystem.BoundingBox;
        double minVelocity = 0.1333 * FlockSystem.BoundingBox;
        if (Velocity.Length > maxVelocity) Velocity *= maxVelocity / Velocity.Length;
        else if (Velocity.Length < minVelocity) Velocity *= minVelocity / Velocity.Length;
    public void ComputeDesiredVelocity(List<FlockAgent> neighbours/*, Surface surface*/)
        var bounceMultiplier = 10;
            desiredVelocity += new Vector3d((FlockSystem.BoundingBox - Position.X) * bounceMultiplier, 0.0, 0.0);
        else if (Position.X > FlockSystem.BoundingBox)
            desiredVelocity += new Vector3d(-Position.X * bounceMultiplier, 0.0, 0.0);
            desiredVelocity += new Vector3d(0.0, (FlockSystem.BoundingBox - Position.Y) * bounceMultiplier, 0.0);
        else if (Position.Y > FlockSystem.BoundingBox)
            desiredVelocity += new Vector3d(0.0, (-Position.Y) * bounceMultiplier, 0.0);
        //if (Position.Z < 0.0)
        //    desiredVelocity += new Vector3d(0.0, 0.0, -Position.Z);
        //else if (Position.Z > boundingBoxSize)
        //    desiredVelocity += new Vector3d(0.0, 0.0, boundingBoxSize - Position.Z);
        else
using System;
public class GhcFlockingOnSrf : GH_Component
    public GhcFlockingOnSrf()
        : base(
              "Flocking on surface",
              "FlockOnSrf",
              "Creates a swarm on a surface",
              "YFAtools",
              "AgentBased")
        //pManager.AddBooleanParameter("3D", "3D", "3D", GH_ParamAccess.item, true);
         bool iReset = true;
        bool iPlay = false;
        //bool i3D = false;
        Surface surface = null;
        int iCount = 0;
        //DA.GetData("3D", ref i3D);
        if (!DA.GetData(2, ref surface)) { return; }
            flockSystem = new FlockSystem(iCount/*, i3D*/, surface.ToNurbsSurface());
        else
            //flockSystem.Surface = surface.ToNurbsSurface();
            // Update the flock
            if (iUseRTree)
            else
        // Reparameterize Surface (You're not reparameterizing the surface here)
            var pointToTranslate = agent.Position;
            positions.Add(new GH_Point(surface.PointAt(pointToTranslate.X, pointToTranslate.Y)));
        DA.SetDataList("Positions", positions);
    public override Guid ComponentGuid { get { return new Guid("fbaaaf6f-e579-4f63-92e5-93642831c343"); } }
How do you expect me to find a mistake I don’t know about there?
Okay so the mistake is here I created a point on the UV coordinates of surface I can’t make an xy vector into a UV vector
_surface.PointAt(tu, tv),new Vector3d(Point3d.Subtract(_surface.PointAt(tu, tv), _surface.PointAt(vectorX, vectory))) );
                Agents.Add(agent);
An easy way, extract the perp frame at tu,tv and proyect your 3d vector in that plane. But of course you’ll have to project the new position to the surface after updating.
@youssef_aboualghar I am trying to solve the same problem through C# and being a novice, I haven’t reached very far.
Would it be possible for you to share your Rhino and Grasshopper / VS files for this solution?
@youssef_aboualghar Hi Youssef, your code is awesome.
the only error I am getting is with regards to the function of Util.cs.
Could you please share your Util.cs file, I believe it has more logic added to it than the original Util file from Long Nguyen’s workshop.
Thank you and best regards.
