Hi @Mahdiyar thanks, and have been enjoying playing with it and modifying the adjust the embedded formula’s and variables on the fly to get the full diversity and see what can be done with this code.
i have 3 questions which i hope you can answer:
sometime the shader displayed geometry goes missing, stops rendering. this also happens in your original example, Say you try zoom in from Top view to get really close, and then the object stops being rendered, while still visible in the other views Perspective and Front
I am looking for a way you get change dynamicly change the code from gh, without changing it in the editor
I wanted to add a clipping, so slicing the geometry and moving the slce plane in all xyz directions
Innitially I want to externalize internal code line like this
z = zr*vec3(sin(theta) * cos(phi), cos(theta), sin(theta) * sin(phi));
But it seems externalizing specific lines of shader code or mathematical expressions to be dynamically loaded or modified from an external source like a text file is not directly supported within the standard GLSL shader compilation process. So I now externalized parameters like zr , theta , and phi as uniforms to allow additional external control.
Defining Uniforms
// External variables
uniform float initialDistanceRate; // Initially 'dr = 1.0'
uniform float initialRadius; // Initially 'r = 0.0'
uniform int maxIterations; // Loop control, originally 'for (int i = 0; i < 32 ; i++)'
uniform float breakRadius; // Condition to break loop, originally 'if (r > 4.0) break;'
// Externalizing constants in mathematical operations
uniform float powerAdjustment; // To adjust 'power' dynamically
uniform float additionAfterMultiplication; // Originally "+ 1.0" in the 'dr' calculation
// Individual trigonometric function control for each operation
uniform int trigFuncThetaX; // Controls the function used for 'theta' calculation (x component)
uniform int trigFuncThetaY; // Controls the function used for 'theta' calculation (y component)
uniform int trigFuncPhiX; // Controls the function used for 'phi' calculation (x component)
uniform int trigFuncPhiZ; // Controls the function used for 'phi' calculation (z component)
uniform int trigFuncZx; // Controls trig function for z.x component
uniform int trigFuncZy; // Controls trig function for z.y component
uniform int trigFuncZz; // Controls trig function for z.z component
Select Trigonometric Function
float applyTrigFunction(int funcId, float value) {
if(funcId == 0) return sin(value);
else if(funcId == 1) return cos(value);
else if(funcId == 2) return tan(value);
else if(funcId == 3) return asin(clamp(value, -1.0, 1.0));
else if(funcId == 4) return acos(clamp(value, -1.0, 1.0));
else if(funcId == 5) return atan(value); //
else return value; //, should not happen
main loop
float dr = initialDistanceRate;
float r = initialRadius;
for (int i = 0; i < maxIterations; i++) {
r = length(z);
steps = i;
if (r > breakRadius) break;
// Apply individual trigonometric functions
float theta = applyTrigFunction(trigFuncThetaY, z.y / r);
float phi = applyTrigFunction(trigFuncPhiZ, z.z / r);
dr = pow(r, powerAdjustment) * power * dr + additionAfterMultiplication;
float zr = pow(r, power);
theta = applyTrigFunction(trigFuncThetaX, theta * power);
phi = applyTrigFunction(trigFuncPhiX, phi * power);
// Construct 'z' using individually controlled trig functions
z = zr * vec3(
applyTrigFunction(trigFuncZx, theta) * applyTrigFunction(trigFuncZx, phi),
applyTrigFunction(trigFuncZy, cos(theta)), // Example adjustment
applyTrigFunction(trigFuncZz, sin(theta)) * applyTrigFunction(trigFuncZz, phi)
z += pos;
return 0.5 * log(r) * r / dr;
- I also tried to get some type op clipping/slicing the geometry, but this seems to be restricted to the initial size of the 4 vertex points
# version 330
layout(location = 0) in vec3 vertex;
uniform mat4 _worldToClip;
out vec4 vertex_color;
uniform float _vertexDisplacement;
uniform vec3 _displacementDirection;
uniform float displacementScale;
void main() {
vec3 displacedVertex = vertex + (_displacementDirection * _vertexDisplacement * displacementScale);
gl_Position = _worldToClip * vec4(displacedVertex, 1.0);
