Making custom diagonal lines on a surface
Hi all,
I hope some of the expert in here can give me an insight.
I wanted to make a parametric fin on a surface.
If it is just a rectangular panel with normal UV direction, it is quite easy to do so.
However, I wanted to make it so that the panel can be rotated at certain angle like this image:
I tried using lunchbox but the diamond tools seems not what I am looking for
I wanted to create series of diagonal line so that later on I can use those line to either extrude it or modify it further. But I can’t seem to find an example of anyone doing that
I hope someone has an experience of doing this
Thank you
(I have attached my file)
test diagonal.gh (9.3 KB)
Something like this?
test diagonal-b.gh (16.3 KB)
Thank you, Ethan!
Exactly what I need.
I haven’t tried using contour before.
