Making clickable icons through the display pipeline
Ah dang, I had actually written an example file for the AECtech workshop that does that too (i.e. shooting rays along the frustum line at the mouse position onto a list of meshes and drawing the closest hit mesh):
""" Highlight closest mesh under mouse position. Author: Anders Holden Deleuran """
import Rhino as rc
import Grasshopper as gh
import System.Drawing as sd
import GhPython.Assemblies.ExecutingComponent as component
class MyMouseCallback(rc.UI.MouseCallback):
    def __init__(self):
        self.move = None
    def OnMouseMove(self,arg):
        self.move = arg
        ghenv.Component.ExpireSolution(True)
class MyComponent(component):
    def RunScript(self,Meshes):
        self.meshes = Meshes
        self.material = rc.Display.DisplayMaterial()
    def DrawViewportMeshes(self,arg):
        # Get mouse viewport position
        if self.mouse.move:
            mpt = self.mouse.move.ViewportPoint
            # Make ray along frustum line at mouse
            r,fl = arg.Viewport.GetFrustumLine(mpt.X,mpt.Y)
            ray = rc.Geometry.Ray3d(fl.From,fl.Direction)
            # Shot ray onto meshes
            hitMeshes = []
            hitParams = []
            for m in self.meshes:
                t = rc.Geometry.Intersect.Intersection.MeshRay(m,ray)
                if t >= 0.0:
                    hitMeshes.append(m)
                    hitParams.append(t)
            # Get closest hit mesh and draw it
            if hitParams:
                hm = hitMeshes[hitParams.index(max(hitParams))]
                arg.Display.DrawMeshShaded(hm,self.material)
    def __enter__(self):
        self.mouse = MyMouseCallback()
        self.mouse.Enabled = True
    def __exit__(self):
        self.mouse.Enabled = False
        del self.mouse
240705_HighlightMeshUnderMouse_00.gh (5.8 KB)
Which is close to what @mrhe is suggesting, I think. But also pretty off topic, which I think was clickable HUD elements. But who cares, this is a great topic now. Thanks guys and happy Friday :partying_face:
Edit: Just added a check to make sure we get a mouse position, which was causing an error report in the Rhino command line upon initialisation.
Thanks @AndersDeleuran this seems to be much more stable than my solution!
Silly question though, how do I simply output the index of the hit mesh?
I’ve never actually done this, but one can get/output data from inside DrawViewportMeshes like so:
240705_HighlightMeshUnderMouse_01.gh (6.3 KB)
If the goal is to output things and draw them downstream, it might be easier to do all the raycasting business inside the RunScript scope though.
Edit: Forgot to add self.hitMesh = None on line 49:
240705_HighlightMeshUnderMouse_02.gh (6.6 KB)
Before optimizing prematurely, benchmark it. Ray casting is fast, really fast. Granted, Rhino’s implementation is not as fast as embree or optix, but you should be easily able to cast a few thousand rays and maintain interactive performance. What tends to be the bottleneck, though, are simple view redraw calls with denser scenes.
Setup a test scene with 1.000 objects and redraw your view on mouse move. No other logic is executed there. Now, make it 10.000, then 100.000 objects. At some point your model will slow down to a crawl, and there is very little you can do about it.
As for ray casting itself. There are many strategies to speed this up:
  1. Multithread it
  2. Introduce a broad collision phase where you first check a bounding box and only if it is hit, you proceed to the narrow and more expensive collision test
  3. Use some sort of space partitioning structure. Rhino has the Rtree class, embree uses its own BVH (bounding volume hierarchy), but it could also be a screen space grid
  4. Join all meshes into one and only ever shoot one ray (you’d get the original mesh id based on a lookup table keeping track of original face indices). Joining meshes is slow but if you only do it once, it might be worth it
  5. Any combination of the above methods.
All depends on your use case.
Good luck exploring the options!
Thanks @AndersDeleuran ,
I still need to pull the raytrace logic out of the Draw function but I modified to be able to get a selected index as well so that it now supports selection and hover:
import Rhino as rc
import scriptcontext as sc
import ghpythonlib.component as component  # Changed to this for Python 3
    def __init__(self):
        self.move = None
        self.click = None
    def OnMouseDown(self, e):
        self.click = True
        self.button = e.Button
    def OnMouseUp(self, arg):
        self.click = False
    def OnMouseMove(self, arg):
        self.move = arg
    def RunScript(self, Meshes: list[object]):
        return self.hitMesh, self.hitIndex, self.SelectedIndex
    def DrawViewportMeshes(self, arg):
        if self.mouse.move:
            r, fl = arg.Viewport.GetFrustumLine(mpt.X, mpt.Y)
            ray = rc.Geometry.Ray3d(fl.From, fl.Direction)
            hitMeshes = []
            hitParams = []
            hitIndices = []
            for i, m in enumerate(self.meshes):
                t = rc.Geometry.Intersect.Intersection.MeshRay(m, ray)
                if t >= 0.0:
                    hitMeshes.append(m)
                    hitParams.append(t)
                    hitIndices.append(i)
            if hitParams:
                hm = hitMeshes[hitParams.index(min(hitParams))]
                hi = hitIndices[hitParams.index(min(hitParams))]
                # self.hitMesh = hm
                self.hitMesh = None
                self.hitIndex = hi
                if self.mouse.click and str(self.mouse.button) == "Left":
                    sc.sticky["sel_index"] = hi
                    self.SelectedIndex = sc.sticky["sel_index"]
                else:
            else:
                self.hitMesh = None
                self.hitIndex = None
        self.hitMesh = None
        self.SelectedIndex = None
    def __exit__(self):
        del self.mouse
Pretty sure there’s some stuff in here I don’t need anymore so I’ll comeback and clean it up and reupload that version but just sharing for now.
Thanks for the help!
I really appreciate the advice and ideas, thank you for sharing as always!
Hey @michaelvollrath,
Eto’s co-ordinates are in logical pixels which is not quite compatible when you have different DPIs, or even multiple screens (due to how Windows treats coordinates in system-dpi aware mode vs Eto’s multi-monitor dpi aware mode). To convert a point in physical pixels (e.g. what you get from the viewport, or windows forms APIs, etc), you can use Rhino.UI.EtoExtensions.ToEtoScreen(myPointOrRect). This API was added in Rhino 8.7, and directly calls Eto’s Eto.Forms.WpfHelpers.ToEtoScreen() in Eto.Wpf.dll.
There’s also a Rhino.UI.EtoExtensions.ToSystemDrawingScreen() to convert in the opposite direction, if needed.
Hope this helps!
Your unstoppable determination is sensational. I hope you know I’m taking my sweet time with this example because it’s fun to see what happens when you’re left unattended with an exciting problem.
Thank you @curtisw this is perfect! I went on vacation recently (laptop) and couldn’t work on my UI developments because the DPI thing had me completely stumped. I’m looking forward to updating with the methods you mentioned, thank you for the information!
:laughing: Don’t take too long though, I’m about to stress test on some massive files and quite confident these solutions won’t stand the abuse and will likely need a life raft, but hopefully I’ll be pleasantly surprised!
Here’s a quick update that demonstrates how to move all the business logic into RunScript instead (i.e. how to get the mouse location and frustrum line without the arg variable). One should probably just wrap it into a function actually. I also cranked up the mesh sphere count to 1000 and made them more dense to benchmark, this does not appear to affect performance notably on my system:
Get closest mesh under mouse location.
Version: 240706
import Rhino as rc
    def __init__(self):
        self.move = None
        self.move = arg
        mpt = rc.RhinoDoc.ActiveDoc.Views.ActiveView.ScreenToClient(rc.UI.MouseCursor.Location)
        r,fl = rc.RhinoDoc.ActiveDoc.Views.ActiveView.ActiveViewport.GetFrustumLine(mpt.X,mpt.Y)
        hitMeshes = []
        hitParams = []
        for m in Meshes:
            if t >= 0.0:
                hitMeshes.append(m)
                hitParams.append(t)
        # Get closest hit mesh and return it
        if hitParams:
            return hitMeshes[hitParams.index(max(hitParams))]
        else:
            return []
    def __exit__(self):
        del self.mouse
240706_GetMeshUnderMouse_00.gh (6.7 KB)
Edit: When I went to 5000 spheres with 2500 faces each, the profiler started kicking in. It still doesn’t feel too laggy though, quite snappy actually:
Forgot about returning the index. Here’s a nice terse method for dealing with that:
240706_GetMeshUnderMouse_01.gh (9.0 KB)
Love it! Thanks @AndersDeleuran , works great on my end as well! I’m about to test on some of the ā€œbloatedā€ models from the public ICON Initiative 99 competition repository here since a lot of these have no garbage management in them.
Also, happy anniversary! :partying_face:
Hehe, likewise. Funny coincidence :slightly_smiling_face:
Had some fun augmenting the script to allow multi-selection, un-selection, and selection clearing logic:
I think my conditional statements on index handling are just a little bit goofy in certain cases so I’m trying to track down what’s going on there but otherwise it’s a pretty fluid interaction I am very happy with so far.
EDIT:
Forgot to attach the code:
Version: 240706
Modified By: Michael Vollrath
Features Added: Python 3, Clickable Selection, Multi-Selection, De-Selection, Selection Clearing
import Rhino as rc
from Rhino.UI import ModifierKey
    def __init__(self):
        self.move = None
        self.click = None
        self.button = None
        self.modifier = None
        sc.sticky["sel_indices"] = []  # Initialize as an empty list
        self.move = arg
        self.ctrl = e.CtrlKeyDown
        self.shift = e.ShiftKeyDown
        self.click = True
    def OnMouseUp(self, e):
        self.click = False
        r, fl = rc.RhinoDoc.ActiveDoc.Views.ActiveView.ActiveViewport.GetFrustumLine(mpt.X, mpt.Y)
        hits = []
        for i, m in enumerate(Meshes):
            if t >= 0.0:
                hits.append((t, i, m))
        # Get closest hit index/mesh and return those
        if hits:
            hits.sort(reverse=True)
            t, i, m = hits[0]
            # rc.RhinoApp.WriteLine("Get Hovered Sticky Value")
            sel_indices = sc.sticky["sel_indices"] if "sel_indices" in sc.sticky else []
                if self.mouse.shift:  # Multi-select with Shift key
                    if i not in sel_indices:
                        sel_indices.append(i)
                elif self.mouse.ctrl:  # Remove selection with Ctrl key
                    if i in sel_indices:
                        sel_indices.remove(i)
                else:  # Single select
                    sel_indices = [i]
                sc.sticky["sel_indices"] = sel_indices
                return i, sel_indices
        elif self.mouse.click and str(self.mouse.button) == "Left":
            # rc.RhinoApp.WriteLine("Clear Sticky")
            sc.sticky["sel_indices"] = []  # Clear Sticky If No Valid Hit On Mouse Click
            return [], sel_indices
        else:
            # rc.RhinoApp.WriteLine("Get Selected Sticky Value")
    def __exit__(self):
        del self.mouse
That’s awesome. This has been a very fun AND useful one. And just for completeness, should OP ever come back, here’s a quick go at drawing a rectangular 2D swatch/icon in the viewport foreground with a left mouse clickable state (purple dots in the video are right clicks, yellow are left clicks, using PowerToys):
240707_MouseOverClickableState_00.gh (5.6 KB)
Very cool! This will definitely come in handy! Thanks for sharing!
(Also I forgot to add the code for the multi-select, editing the post above with that code now)
Oddly, the code ā€œworksā€ on Mac OS except that there is a big vertical offset in terms of where the ā€œhit locationā€ is and where the mouse cursor is. My guess is it’s happening in the RayCasting function or .ScreenToClient
Have you ever come across that? I imagine you mostly use Windows?
Afraid not, I’m indeed mostly/only on Windows.
Just to rule things out, do the GhPython components I’ve posted also not work as expected on Mac? Or is it just the new script editor CPython 3 implementations? Either way, it’s maybe something for @CallumSykes or @curtisw to have a look at.
Hmm I’m not sure I’ve only tested the Py3 versions. Good Question, I’ll report back with findings
You are wizards! I love this community and what you share. Thank you so much!!! Amazing discussion in here.
@curtisw
Thanks for the answer! This is something we have been trying to do as well and we ended up using a lot of workaround to ensure we got the right screen point.
This might be a rather dumb question, but here goes…
I tried downloaded the nuget Eto.Platform.Wpf.
When I tried to call this line, it returned with a CS0012 error.
I am not sure why that is because Eto.dll and Eto.Wpf.dll were both referenced in the packages… What am I missing?
