Makehole does the opposite of what they are supposed to do
Hi all,
in my latest project, I tried to make a BooleanDifference between two polysurfaces (substracting the beige brep from the selected grey one), but instead it created a BooleanUnion
Then I tried to use a MakeHole, but somehow it did the exact opposite of making a hole
Those closed polysurfaces were created using the following grasshopper script:
Thank you in advance
251207_Maquette-finale.3dm (12.4 MB)
extrude surface.gh (10.8 KB)
Here are the System Infos:
Rhino 8 SR18 2025-4-10 (Rhino 8, 8.18.25100.11001, Git hash:master @ 5d157e876c23ece334d9c8666b8513ffc6d4a98d)
License type: Educational, build 2025-04-10
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [94% battery remaining]
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.4032
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.4032
Integrated (slow!) graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.4032
Driver Date: 12-21-2022
Driver Version: 31.0.101.4032
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.18.25100.11001
C:\Users\thore\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
the problem are the normals of your polysurface they point inwards:
_explode
_join (will fix it automatically)
here is something to play with:
do a boolean difference: lower piece minus the upper one..
(red surface = normal reversed)
boolParty.3dm (3.4 MB)
kind regards - tom
