Make a scale Rectangle with Area limitation
Dear my friends!
01.|690x297 01.Rectangle.gh (3.3 KB)
as you see we have a rectangle with area=200 and now I want to scale it without changing of area.
for instance, I want to make another multiple shape (Rectangle or square ) with the limit area = 200
the center area is the corner of the rectangle.
like this :slight_smile:
All of the rectangles have same area.
See here: How to scale a surface to a certain wanted surface area?
There is native grasshopper components versions posted as well as Pufferfish Scale To Area component version. Also, if it is a rectangle you can just make it that way to start instead of scaling with Pufferfish’s Constrained Area Rectangle component.
I think It is not my answer!
please look at picture that i have attached.
It is the answer, the issue is that you didn’t open any files or look at the post :smiley: Set the plane Pl input to that corner.
I want to convert Black rectangle to another rectangle with the same area (200)
like the red and yellow and green one
And that is exactly what I posted to you, did you even look at it?
Here is the Pf version:
ScaleToAreaPf.gh (10.9 KB)
Great!
but i think I should start to learn Pufferfish.
Here is a native way.
ScaleToAreaNative.gh (12.0 KB)
Thank you so much!
