Make 2D for the original version of SubD object
I have the non-smooth version of these SubD objects that I would love to get the make2D from. However, when I make2D, I get the make2D of the smooth versions instead. I wonder if there is a way I can get the make 2D of the non-smooth version.
Thank you for your support
Hi -
You can run ExtractControlPolygon on the SubD object and then run Make2D on the output of that command.
Thank you so much It worked wonderfully :slight_smile:
