fujihira
(Fujihira)
June 20, 2023, 5:00am
1
In the sample project , where ShowSemiModal for WPF is used, MainWindowHandle gives the following error.
System.ComponentModel.Win32Exception: "Invalid window handle"
If you execute a command with a button while SemiModal is displayed, SemiModal will be closed forcibly. Then, when the “SampleCsWpfSemiModalDialog” command is executed again, an error occurs and the modal is not displayed.
The same phenomenon did not occur with SemiModal for Windows.Form. I checked with the sample “SampleCsSemiModalForm”.
Thank you if someone knows what is happening.
dale
(Dale Fugier)
June 20, 2023, 5:54pm
2
Hi @fujihira ,
I am not able to repeat what you’re reporting. Can you run Rhino’s SystemInfo
command and post your results? What version of Visual Studio are you using?
– Dale
fujihira
(Fujihira)
June 21, 2023, 12:17am
3
Hi @dale ,
Thank you for your time.
Below are the results of the SystemInfo
command.
Rhino 7 SR30 2023-6-12 (Rhino 7, 7.30.23163.13001, Git hash:master @ f695e494df78377a81b2b95edb99c6067e324b33)
License type: 商用版、ビルド 2023-06-12
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1080 Ti (NVidia) Memory: 11GB, Driver date: 5-24-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 535.98
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-24-2023
Driver Version: 31.0.15.3598
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\work\0001_code\rhino-developer-samples-7\rhinocommon\cs\bin\SampleCsWizardPanel.rhp "SampleCsWizardPanel" 6.0.0.0
C:\work\0001_code\rhino-developer-samples-7\rhinocommon\cs\bin\SampleCsWpf.rhp "SampleCsWpf" 6.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhinoレンダー" 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
Below is the version of VisualStudio.
Microsoft Visual Studio Community 2019
Version 16.11.26
I will also post a video reproducing the error.
Thanks.
