In Work In Progress (7.0.20238.17095, 8/25/2020) the C# component Split call returns 6 breps and surfs[0] is null.
I tried to create a grasshopper file with a C# script node to illustrate the problem. It has a third, different, behavior. I assigned surfs to A and got three values (null, trimmed surface, trimmed surface)
Its a slightly inefficient but general work around.
I considered it but, surprisingly, there are only about five places in my code where I used Split so I just hacked my indexes to get what I wanted.
I’m prepared to take the hit and alter my code again when the Split method is fixed.
Now that I think about it… I could have written a method that did your hack internally. Then, when the fix was made I could delete the method then fix each location where the compiler flags an error. It would have been quicker.
But no matter, I’m glad the bug is being addressed.
