While fitting a curve through linear regression method, using Grasshopper LunchBox, I noticed numbers do not match up with those calculated by python. However small, the discrepancy is really annoying.
The second issue is the way input and output data are used in the template file provided by the plug-in developer. I suspect the input seeks “two or more” independent data—or predictors—whereas the output is where the dependent data is fed. The template shows otherwise; two output and one input.
How do we interpret this discrepancy?
if the question is fundamentally wrong, I would appreciate it if anyone could show me what the right question is like.
