Hello all,
I’ve run into a bit of conundrum and I’m not sure why it’s behaving the way it is, I wonder if someone might be able to shed some light?
I have a number of curves which can be lofted in Rhino simultaneously without any issue, however when I try to do it in GH in one go it seems to fails with little to say as to why. It works if I loft two curves at a time to deliver the same result though.
Can anyone see why these lofts might fail?
Thank you,
Sash
Edit: it seems the surface freaks out a little when you try to join and cap the GH surfaces - see right object in last image
Sash_ColumnWeave.gh (14.0 KB)
